It is currently Sat Aug 09, 2025 7:00 am
PostPosted: Sun Feb 05, 2017 6:47 pm
I have a stack of pretty nice Italian spruce, however, they're all P size only.
What is the proper method of adding the wings to widen the lower bout?
PostPosted: Sun Feb 05, 2017 7:11 pm
Last Name: Kincheloe
I haven't done one myself, but theoretically the runout should be best matched if you swap the waist cutoffs. So glue the treble side waist cutoff to the bass side lower bout, and vice versa.
Flipping it over across the grain inverts the runout, but flipping along the grain doesn't. And to get the straight edges together, you have to do a horizontal flip (or rotate 180 degrees, which is equivalent to horizontal flip followed by vertical flip). So start with the opposite runout and you can't lose :)
PostPosted: Sun Feb 05, 2017 7:17 pm
Last Name: Cox
So what are you trying to do?
Squeeze a 14" lower bout out of a 13" top or make a D size out of a 12" top.
One - you just use the upper bout cutoffs oriented to keep the runout the same.....
The other will require gluing a second book matched top set to the first.
PostPosted: Mon Feb 06, 2017 8:20 pm
Last Name: Livermore
State: Minnesota
Or make 3 piece tops without a center seam
Users browsing this forum: TRein and 49 guests
